Carven Exhaust Tips
pguerrero693
Just installed the exhaust.. Sounds awesome. Real mean. Only one problem:
Did anyone else have trouble with the tip alignment? They seem to be going slightly left and my left side is lower. Tried centering it but nothing. The hangers don’t allow a lot of play. If I don’t find a solution I may have to hit a muffler shop. Any advice? Thanks.
Same problem here. Seems to be pretty common. It's an issue with the rear hangers. I called them and they sent me new rear sections, just haven't had the chance to put them on and see if they line up any better.
Damn. I knew there was something wrong. Maybe there’s someone that got the rear hangers and that hopefully fixed the problem
****. I knew there was something wrong. Maybe there’s someone that got the rear hangers and that hopefully fixed the problem
The hanger is welded to the pipe. The new ones they sent me look like they will work much better and will not allow as much movement.
Did the new ones ever fix the problem? I'm having the same issue
Honestly, I still have them sitting in my garage and haven't done anything with them yet.
