Jeffrey_Sasquatch
- Sep 1, 2020
It has been confirmed that on a great many Key-less Ignition RAM trucks, if equipped, the LED 3rd brake light can cause a malfunction in the Key-less RF system. Certain brands of LED's generate a frequency that interferes with the Key-less Systems ability to detect the FOB, thus generating the message "FOB NOT DETECTED and or FOB HAS LEFT THE VEHICLE". Once the LED chip is removed from the 3rd brake light and either replaced with a standard halogen bulb and or a known safe LED chip, the error issue should go away. If not you may have a deeper issue, maybe with your RF MOD and or your ECM, BCM or maybe something so simple as a bad battery in the FOB.
