2020 Ram 1500 BTS with 295/60r20 no lift/no rub
ZCoffman
Sioux City, IA
Well I have owned this thing since April 2020 and I finally got around to throwing new tires on it. Atturo X/T's 295/60r20. Bought a level thinking I needed it, found out it wasn't even needed. Clears without issue. Doesn't even rub the mud flaps. That's a win. I think the only thing I might do is put like 1/4" spacers on it to put the wheels out just a hair. Heck I don't think I even lost any MPG, I calibrated the speedo with my Pulsar and my cellphone speedo and she is spot on. I drove down my normal route and got the same MPG as before, but I bet the first set of winter winds, this thing will get 12mpg instead of 14mpg lol. When I can get to a car wash I'll show her off a tad more.
I got th same on 285/65/20 and I removed th side steps after this pic it’s a much cleaner look
I put Eibach adjustable shocks on the 3rd clip and have the ORP springs that came with the BTS so they’re a inch taller leaving my truck perfectly leveled
That looks really good. You have stock suspension? Off road group? Just ordered a limited with off road group and I'm trying to figure out the largest tire I can fit with no rubbing or trimming on the stock suspension with no spacers?
Thanks!
Thanks!
I only added th eibachs at the 3rd clip and rc control arms. I have 285/65/20 and had to trim th liner a little bit.
Thanks!
My Built to Serve has the Offroad Group on it with Heavy Duty struts and I have found that these Atturo's run undersized, they actually measure out to be like 33.5" tires instead of 34.2" like they are advertised. But no rub unless you are full lock and flexing a bit. Or have a full cab. Honestly I think the only thing I might do is get the smallest level there is and that will be it. But we will see what this winter holds, I doubt I'm going to need to get the level on it.
