Confirming Truck towing, plowing and payload numbers -- charts
grimloktt
Ii'm trying to verify I'm operating w/n my truck's limits. Are these numbers right?
Payload: 1,300 pounds according to door sticker. So, subtracting my weight and crap I can load about 1k pounds into the truck.
Towing: 11,290 pounds
Plow/Front axle: 818 pounds (3900 front GAWR-3082 front base weight).
- Can I use 650 pound plow/mount? If I subtract my weight from 818, I'm slightly over?
Sent from my SM-T870 using Tapatalk
No, the trailer is most likely about 1600 payload so you could not tow it. For that sized trailer, the tongue weight would be about 15% plus the WD hitch.
250 lbs of driver weight is already considered in payload capacity, if I'm not mistaken. And a full tank of gas. You shouldn't need to factor that into your calculations. Still, the best way to know is the cat scale, as stated above.
I don't know what year your truck is, but if you're really trying to follow the rules, my 2020 owners manual clearly states you shouldn't attach a plow.
Wrong. Fuels are accounted for, but no passengers. The sticker clearly states that all occupants and cargo shall not exceed the limits set forth.
I posted this information on plowsite w/ updated information. Seems like the answer is I will probably be OK but with likely increased wear/maintenance costs but a larger truck would be more ideal.
I wouldn't plow with a 1500 unless it was just a couple driveways. More commercially and you'll benefit from a 2500 or 3500.
