reapur
- Jul 11, 2022
Hello,
Hopefully this is the right subforum for maximum eyeballs
2022 Ram 1500 Limited etorque
I recently got a BLUETTI Portable Power Station EB3A, and right away I noticed that it was throwing a short when I try to charge it from the AC outlet, either the one in the front or the back.
Charging it from the Cig outlet works fine, but it's all the way up on the dash and not very convenient to charge the power stations and the fridge in the back seat.
So I tested the outlets with a line tester and here are the results:
Both outlets are showing open ground which I suspect is tripping the power station.
I checked the outlets around the house and they all show the "correct" position. I don't have other cars with outlets to test.
Is this by design? Is there anything I can do to fix this?
Thanks
Thanks
