Does the TazerDT do the same thing as alfaOBD?I use that obd scanner. I have a Tazerdt, so don't need bypass harness
Yes and no. There are things they both do. But there are live features the TazerDT gast that alfaOBD can't do, and there are changes you can make with alfaObd that haven't been set up on the TazerDT. Theoretically the TazerDT could do everything alfaObd can, but it would need programmed to do it by Z-Automotive.Does the TazerDT do the same thing as alfaOBD?
Is the tazerDT really $300? The alfaOBD app is like $50 and the bluetooth connector is $25 and the bypass cable is like $20. I don't know what the differences are between alfa and the tazer because I have zero experience with either. The only real things I want to do is cancel the fog light drop out with high beams, add the tailgate down warning light and add the right side auto dimming mirror if possible. As far as diagnostics, I'm a mechanic so I'm not worried about that so I don't think I can justify the extra cost for the tazerDTYes and no. There are things they both do. But there are live features the TazerDT gast that alfaOBD can't do, and there are changes you can make with alfaObd that haven't been set up on the TazerDT. Theoretically the TazerDT could do everything alfaObd can, but it would need programmed to do it by Z-Automotive.
Here are the list of things only the TazerDT can give you. If none of these are important to you, then it's not worth it. Not all of them are available for all trim levels and/or option packagesIs the tazerDT really $300? The alfaOBD app is like $50 and the bluetooth connector is $25 and the bypass cable is like $20. I don't know what the differences are between alfa and the tazer because I have zero experience with either. The only real things I want to do is cancel the fog light drop out with high beams, add the tailgate down warning light and add the right side auto dimming mirror if possible. As far as diagnostics, I'm a mechanic so I'm not worried about that so I don't think I can justify the extra cost for the tazerDT
