Stock 22" wheels with 35s tires
Dontfront82
Texas
I wrapped my 22 inch stock ram wheels in 35x12.5r22 thunderer tires.
Rides good and not loud. Easy and clean set up. No rub or cutting.
3.5 lift rough country
19Jake
that looks really good
no goofy offset wheels & a proper lift...nice work
Rayco
That looks good I also put 35x12.50r 22 ridge grapplers on those same wheels. 2” level and i had to do some trimming to make them work. I also put 2” wheel spacers to give it a stance that completely changes the look of the truck. Rides better than factory but I feel like the fuel gauge is dropping very fast
Savagescott
Pics?
Remas Ram
Here’s some pics
nice truck, does it have the panoroof?...im considering the black edition crew cab....doesnt have the panoroof which is putting me on the fence in some ways....also has the 3.21 axle...is that a negative....i will pull my utility trailer here and there but not very loaded and not very often.
Rayco
Yes it has pano roof it’s a loaded Laramie. When I test drove one with the lower gears it didn’t feel as peppy. But I also have the etourque that might give it that little extra boost
SeanGTS
How much is a little trimming? Any pictures? Which 2" lift?
Savagescott
Here’s some pics
Looks really good. How much and what kind of trimming did you have to do? How do you think an extra 1" of height (say, with the Off Road Group) would affect the amount of trimming needed?
Rayco
1 inch of lift would help. It’s removing the small black plastic deflector, zip tieing the wheels in and cutting the bracket off. Also molding the wheel wheels with the heat gun. It still has minor plastic rubbing in reverse at full lock sometimes the 1” extra will eliminate that
Mx113
This is 35/12.5r20 KO2s on stock rims. 1.5 inch hub centric wheel spacers. 3.5 inch ready lift
