ORG front springs question..
Well, I can tell you that I went with the 68320249AC spring and they were actually pretty cheap. I put them on Bilstein 5100s set on 4 and ended up with 2.5" 1.5 from the #4 setting and 1" from the spring. Now I am sure Mopar has more than one spring that is used for ORG. Do a search on here for ORG springs and I am sure you can find enough information to make a decision.
I believe you are correct just based on the fact that we have 2 part numbers both of which achieved the same thing.
the picture I posted came from my truck which has the org from factory, I did the belltech's 1.5" plus the 1" of the spring for 2.5"
OP Both part numbers are pretty cheap online but I get that the main thing is you are trying to avoid installing the wrong spring
maybe drop by the parts department and ask
there isn't a lot of information about the ORG springs on this forum truth be told.. Lol
I thought about it.. but 99% of parts employees at the dealerships are freaking clueless and only rely off customer's VIN numbers for help.
I think either of the part numbers from above will work with the only possible difference being if you have air ride.
