Level for eco diesel
Fillet1
Looking at leveling struts - looks like the Rough Country 2” kits end up being higher than the rear and then you need to raise the rear to actually be level. I do see that they have a new adjustable strut - but is not “v6” compatible. I am assuming this is weight related - not any structural difference. Link is here: M1 Adjustable Leveling Struts | Monotube | 0-2" | Ram 1500 (19-22)
will this work with the eco?
I will be installing bilstein 5100 front shocks to help level my rebel at the end of the month hopefully. I ordered them in February and just got confirmation that they are on their way to our supplier.
Are you just doing 5100 front shocks? Anything on the rear?
Have a similar build except I have a Laramie. I’m seeing a lot of back and forth on leveling these ED.
Thanks
Can’t you do too hat spacers on the ED trucks?
You can, I decided to go a different route tho.
Also for now I do not plan on replacing the rear shocks or lifting the rear, I just want to level my truck out.
