Rear defrost not working
foxm1013
NEPA
I have 2020 bighorn which had the rear glass replaced about two years ago. after which the rear frost worked fine, now with mornings starting to get colder it seems that it has stopped working. The fuse is fine and the light in the button stays on. I also have heated mirrors and though I believe they are working im not 100% sure as they haven’t been all that fogged as of yet.
Anyone have any suggestions?
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Could be a failed solder connection at one of the "snap buttons" connecting the wires to the glass.
Ratchet
Wilson, NC
As stated above, most likely it's between the defroster tab and the glass. Had exact same issue with mine. Simple repair, but a special adhesive with a high metallic content is required.
foxm1013
NEPA
this is definitely my issue, checked an both sides were snapped off. Can they be resoldered on or should i just use the adhesive?
Belvedere
Just resolder. Sand the contact with some fine grit paper and clean with contact cleaner. Try to replace as much of the old solder off the button as you can, solder wick or compressed air. Then just lightly hold the button with needle nose pliers and apply soldering iron.
Been hearing a lot about this lately. No one else has mentioned if it was the original window. Wondering if these joints are getting weakened by replacement or just replacement contacts aren't as robust.
strat41986
Had the same thing happen to mine. Auto zone or any auto parts store will have a "defrost repair kit." It comes with a conductive adhesive. Just follow the instructions to reattach the contact point to the piece that attaches to the glass.
Rando
Hopefully you’re still around the site. My rear defroster stop after window replacement.
Did the repair work for you?
How did you gain access to the connector? Does it require seat removal?
I appreciate any guidance you might have.
Thanks!
kapinallinen2
Southern Maryland.
Thanks!
If it stopped working right after replacement, take it back and let them figure it out.
Rando
Well I don’t really know when it stopped working. Window was replaced back in February can’t recall if I used the defroster after that. Noticed it wasn’t working recently. Honestly, if the fix isn’t overly complicated I’d rather do it myself.
kapinallinen2
Southern Maryland.
Oh. OK.
foxm1013
NEPA
My home fix has worked and continued to work since i made this thread. Not too difficult if you take your time and have someone that can help with the seats.
TasteeWheat
@foxm1013 What was your final "home fix" solution? Did you go with resoldering, adhesive, or the "defroster repair kit" mentioned above?
