Upgrade to 22s or keep 20s
Whitby, Ontario
So, I'm always on the lookout to change things on my truck. If I come across something randomly like these rims I start thinking about modifying.
So currently I have the factory Sport rims that I had my rims powder coated black approx 2 years ago. At the same time I had 35"x11.5 Ridge Grapplers installed. I also added Bora wheel spacers 2" Front and 2.5" Back. I think that the factory rims are 18mm and with my spacers it would put front at -32mm offset and -45 on the back (this was to compensate for the Bushwacker Fender Flares so tires will be level with my flares)
These are at -52mm so they should work fine without my spacers. It will end up giving them more poke I'm sure.
These are 33x12.5x22 Venom RT tires and 22" Fast Traxx wheels. About 1 year and person says 28km on them.
Would this be a good trade or should I ask for money? Or will these look weird on my left truck.
MINE
New Ones
I much prefer 20s over 22s on a truck but what you like better is all that matters. Your rubber is probably worth more but his wheels are likely a little more, probably a wash in trade value.
I do think 20s is a perfect balance between sidewall and rim for bigger off road / on road style.
I am worried a little a bit about stiffness with larger rims and small sidewall.
I do like both.
