2019 brakes replace
pfdkep
Is it difficult to replace rear rotors and brakes on a 2019 ram 1500 with the electric e-brake?
not at all, just put the brakes in service mode. You get to that through the radio.
  • Like
Reactions: c3k
What is the procedure to place truck into service mode?
You will want to use a couple jacking bolts to push the rotor off. A 1/2" bolt and two nuts through the caliper bracket. Give the rotor positioning screw a good smack with a hammer before you try to break the torx screw loose too.
