I finally tore into my 2019 Ram 5th Gen Hemi that has had some exhaust leaks since about the 37K mile mark (at least).  The truck currently has 66K and sounds like an old beater.  I had assumed the ticking that I could hear under the hood were broken exhaust manifold bolts, but after investigating that a little bit, I determined that was not the case.  I also had a broken bolt where the intermediate pipe joins the resonator, causing an exhaust leak.  I fixed that and then turned my attention back to the leak under the hood.  After pulling the passenger tire, wheel liner and manifold heat shield, I found a crack in the exhaust manifold.  My question is, what is the best option to fix this?  The cheapest option is to replace with stock manifolds.  I don't want to do that though, as I feel I will have the same issue again, down the road.  The second cheapest option is aftermarket manifolds.  Does anyone have experience with Dorman replacement manifolds?  Third option would be to install shorty headers.  This is the option I am leaning towards, but really don't want to spend that much.  I do plan on having the truck for several more years though, so maybe it will be worth it.  This option also sounds like a painful install.  Just looking for your opinions and experiences with the same issue.  If I go the shorty header route, which ones do you recommend?  I love the truck, but between the exhaust leaks and water leaks, I'm getting a bit frustrated. Thanks in advance!
		 . I did get a quote from a small shop for around $600 but they would need a week or so before they could get to it. My buddy's shop declined to do it. So the dealer won this time. I'll get my truck back later today, but this issue could still happen on the driver side and since they are using OEM bolts and whatnot it could happen again in a few years. Long term it would be nice to get some well made shorty headers that would hopefully not have this issue.
