NorCal Bighorn
- Oct 31, 2021
2021 Ram 1500 bighorn crew cab, 5.7l hemi 12,438 miles
Rough country 3.5 inch lift
Go Rhino BRB 5.5 winch bumper
Milemarker 12k winch
Hey all,
I've been searching the threads as well as the interweb since 5 am this morning. Can't find anything that describes my failure. Just a couple of threads that peeked my interest, and caused me to climb all over my truck before calling the tow truck.
About a week ago, I had a strange electrical gremlin appear in my rig. Heater/a/c fan would increase rpm and decrease rpm for a few minutes, then stop and act normal. When this would occur, my headlamps and tail lamps would flicker as if a bulb was loose or failing. Every time this would happen, i would monitor voltage on my dash and it would fluctuate 1/10th of a volt between 14.2 and 14.4. ( averaging at 14.3) No run ability issues and no starting issues. Truck sat for 3 days while on a little family trip this past weekend. Choose to take wife's F150 (lol) because I hadn't had time to dig into the issue my truck began having. This morning, truck started fine, nothing abnormal noted. Let it warm up a min, then made the 6 mile drive to work.
Upon arrival at work, backed into my parking space and noticed headlights were again flickering, hvac was turned off as it was a beautiful 70 degrees so I had windows down. I let the truck idle for about 2 minutes when it shutdown as if I pressed stop button. Strange thing is, all electrical power was gone. Headlamps were off, dash display and infotainment was blank, no dome lights, nothing.
I disconnected battery and performed a battery test with my Snap On micro VAT. Surface voltage of battery was 13.6. After test, battery voltage was 12.9, and load test was 101% with 744 available CCA. Checked all power and ground connections, and all electrical connections I could locate.
Being unsuccessful on locating issue, truck was loaded onto a tow truck and taken 80 miles to the dealer. I am anxiously awaiting a phone call as to what the malfunction is and how long my truck will be down.
Does any body have any insights as to what may have decided it did not want to work anymore.
Hey all,
