so ram has yet to build my rebel yet, but I can tell you my experience with my previous rig with it.Is there a real benefit to the pedal commander. As far as eco mode and of course the beast mode!!!!!!!.
And pics any one ???
What is your suggestion ???
Great input.so ram has yet to build my rebel yet, but I can tell you my experience with my previous rig with it.
eco mode really dilutes the throttle response a lot. this is useful when you're crawling (while offroading) when you don't want to have too much/ sensitive throttle input. Also useful when you're on the road just cruising since you won't be revving the engine too much. The drawback is if you leave it in eco mode, you will compensate for the diluted throttle response by pushing the throttle more. This defeats the gas saving purpose.
the "beast mode" just cranks up the throttle sensitivity. You have no real HP or torque gain but the engine will rev up a lot faster as the throttle input is increased. Are you any faster? maybe. you feel faster just because when you're at 50% throttle with beast mode the computer reads "we are in full send mode!" and you don't have to push it that much to get the rev up. However, the amount of power your truck makes is predefined. Once you hit 100% power at the engine, even though your throttle is sending signal for "more power," you will not go beyond 100%.
is it worth it? for each his own to be honest. If you want to get it for gas saving purpose... after 5 years of usage I do find that I save some gas. But that is my previous rig was slow to begin with and I just gave up on the power department (which is also why I'm going with a v8 this time). But is it $399 (or whatever they go for these days) gas saving? I'd say not really. BUT if you go offroad and constantly find yourself in the position in need to carefully fineness your throttle input, I'd say go for it.
ill also add that i usually drive it in eco mode to save some gas and to hold myself back from driving like a speed racer, but sometimes I turn it off just to pretend im driving a whole different rig lolGreat input.
Its my daily driver. I mainly monitor my pedal when driving my 30 mile commute round trip to and from work
Ya still concodering they go for 300 nowill also add that i usually drive it in eco mode to save some gas and to hold myself back from driving like a speed racer, but sometimes I turn it off just to pretend im driving a whole different rig lol
That's just part of the PCM programming. No throttle controller is going to fix that slight hesitation when you go full throttle.I’m still seeing throttle lag with my Pedal Commander. It’s perfectly fine when you ease into the throttle but if you mat the accelerator it’s pretty horrible and no better than before.
Maybe there’s something wrong with my truck. Interested if others see the same.![]()
That’s kinda what I figured. Just wanted to clarify that since I see a lot of people claiming the Pedal Commander eliminates ALL throttle hesitation. I thought that myself when I first bought mine but after further testing that hesitation was obviously not completely removed. Only thing that changed is instead of using my full pedal travel I only use about 1/3 in Sport Mode. This is exactly what I expected.That's just part of the PCM programming. No throttle controller is going to fix that slight hesitation when you go full throttle.
iirc i paid $299.99 or something like that back in 2018. If that's the case then it's probably the only thing that hasn't gone up in price.Ya still concodering they go for 300 now
