3/5 IHC Drop Kit Turning Radius
Yungmexico
I Just Recently Installed A Drop Kit On My 2019 Ram 1500 And Im Wondering If Anybody Has Had This Same Problem With Their Turning Radius Being Limited And If They’ve Found A Solution For It. I’d Hate To Have To Do Wide Turns All The Time.
Did you grind off the stops on the knuckles? I cut them flush and sanded the knuckle smooth. Still had reduced radius. My solution was to return to stock lower control arms and use Belltech adjustable coilovers to drop it.
How much turning radius did you loose? Mine went from 1 1/2 turns to 1 1/4 turns. So I only lost a 1/4 of a turn, it is noticeable if I'm trying to do a turn at full lock in a tight spot but everyday driving it is not noticeable to me on mine.
