Swapping upper glove box and dash front from Laramie plastic to limited wood.
PCB
Florida
I have been searching on here and the mopar site to try and find the part numbers for the area across the dash, ignition area, and upper glove box to switch my plain plastic to the dark limited wood with the aluminum button and trim along the bottom. I haven’t been able to locate the part numbers since so many things pop up when I try and search for that area. Has anyone done this successfully? Thanks for your time and help.
I did the exact same thig on my 2019 Big Horn. I got all the parts from e-bay. If you buy the parts OEM, they will cost you around $1000.00 for 3 items.
The little panel on the left alone is about $170. The piece on the steering wheel is $180.
That is awesome that you found the correct parts on eBay. Do you have a seller name or part numbers by chance?
Glove box upper.
Start button trim
Could not find the lower left trim, but I have one brand new for $150.
That was super clutch buddy. Thank you for the reply. Is it just me or do the two parts
Glove box upper.
Start button trim
there have a different tone to the stainless trim along the bottom? One looks more gunmetal than plain stainless than the other. Do you have a pic of the extra part you have and how yours came out? Thanks for the responses.
They are probably just different due to lighting and camera angle. As far as I know there is only one trim for the limited. The chrome looks like gun metal.
Will send you a picture of the part and the truck when I get home.
That sounds like a plan and thank you for your time and help.
Here are some pics. of my setup. I also changed out the trim pieces underneath the glove box and trim pieces.
Some more.
I wish that Limited badge could be removed from the panel. I still want to do this mod though.
Some more.
You did a great job and I love the way it looks. My wife made a good point to me though because we have the gold interior accents and the brown wood look pieces and she doesn’t think it will match well. My plan was to delete the gold and brown wood to do the project but she doesn’t think it will work. How difficult would you say the project was for you?
Not difficult at all. Most of the pieces just snap in. The glove box was a little longer, about 20 min. to change.
Some more.
Do you have the part numbers for top of the radio bezel, rear seat cup holders, door panel inserts and bottom of the steering wheel? I would love to slowly start doing the same with my Laramie.
