I haven't used razor blade cause I don't wanna scratch it. What is the glass stripper? I saw some guys use a clay bar but idk if it'll work. Worth a try I guess. It's like a haze tho not dirthave you tried using a razor blade to scrape it to see if it comes off? Or perhaps use one of those glass stipper?
I'm supposed to get it tinted Tuesday fml lolBefore you do something that might cause issues, take it to the dealer and let them fix it.
tint is insideI'm supposed to get it tinted Tuesday fml lol
Don't use clay on your windshield or any glass.
Use Windex and a paper towel
Then try a Microfiber cloth and rubbing alch
Lastly try a blade, you hold it at a small degree off the windshield, it should be able to slide back and forth without scraping (try on your window at home first so you can see what I mean)
Those look like stains from a rainx product, I know whats extremely unlikely since it's new but thats what ive seen before.
Rubbing alcohol worked wonders to get it off and I used a regular bath towel to clean it off after.
You can also try and apply Rainx spray OVER the area and work it in with a towel and let it dry, then haze, then scrub it off dry.
There are better options for getting your windshield water repelent but none that I know of that could possibly work that stuff off except Rainx, ive no idea whats in that stuff.
He doesn't know what is on his windshield. It's clearly not "clean" It's possible it could drag whatever it is and scratch the windshield.I’m curious as to why you would say not to use a clay bar on glass. It is totally safe and works very well. You just have to make sure the windshield is clean first.
Yes I know that loltint is inside
you made the statement "I'm supposed to get it tinted Tuesday fml lol"Yes I know that lol
Haven't tried alcohol yet. I'll be trying it tomorrow after work. I feel like the glass needs to be "stripped"Have you tried 70 or 90% rubbing alcohol and muscles?
It kinda looks like hard water stains lol.
Well generally you look at the window after the tint is done to make sure it "looks right" and having that crap on isn't going to help.you made the statement "I'm supposed to get it tinted Tuesday fml lol"
that made it look like it would have an affect
getting it tinted has no effect and they might be able to clean it
