Good Afternoon,
This is Matt, the owner of BCA just reaching out with a little update regarding your order and some issues I/we have noticed with a previous batch of DRL lights that we received. We believe that the last batch had some poor soldering joints and that caused some issues with the DRL’s when being installed if the strips were bent too much. The other issue I/we have noticed is with our previous tinted offering that those had a Higher fail rate than what I deemed acceptable. I know that removing the grille is a pain so in order to try to lower the fail rate I worked directly with the manufacturer to tint the molded lenses themselves instead of paying our painter $50 a pair to spray tint them. Between better soldering and the molds being tinted I do believe this will eliminate a great deal of failures moving forward.
If you have already had any type of failure and received a set of replacements, keep those and do as you wish. You will be sent a replacement pair anyway. If you haven’t had any failures, well thank goodness. With all that being said, I/we are getting all the new light strips made into kits and will be sending those to you as well. All customers should receive replacements by month's end. You are only going to be sent the lights themselves with new connectors to attach to the power/ground/turn signal wires. We aren’t going to send new brackets. Keep those, leave them mounted in the grille, and remove the old lights. That will eliminate a little bit of work on your end as well as lower the risk of over bending the lights and possibly damaging them.
If you have any questions, please don’t hesitate to email back to THIS email. Thank you for being a customer and supporting our small business.
Also, made a quick video in regards to the new drl lights, how they look compared to the older ones. Here is a link to update:
BOOM
MR/MRSBOOM (Matt & Kristen Meredith)
Bullseye Custom Autos | Leander, TX
FB/IG: @bullseyecustomautos
