2022 Fuel tank size?
Hank426
Hi, new here. So I just bought a new '22,1500, QC, 6'4", 4x4, 5.7 Hemi with Bighorn level 1, OffRoad group and trailer tow group. How do I find out the fuel tank size on this truck??? It isn't listed on the window sticker and I've read these trucks can have a 23,26, or 33 gallon tanks. Thanks
I can tell you that you don't have a 33 gallon tank. If you did, it would be on the window sticker with an up-charge of $445
I found the build sheet lookup, its a 26 gallon
I have the 33gal. tank upcharge on my window sticker and when the needle is on E with 60 miles to empty it only holds 22 gallons. The part number on the tank says FCA PN - 52029886AA and PO PN - 4103101AA CAPACITY #2. I tried to look it up but got no results.
The tank size is molded into the rear of the tank. I have the 33 gallon and it says 33G.
Thanks, The info I posted above was molded into the back end of the tank on the bottom. I don't see any other info molded into the tank.
did you find out what your tank capacity was? I got the same
