Factory trailer brake controller - can it work automatically below 15 mph?
Confirmed mine does the same this past weekend. It can be very dangerous if you're not planning for it.
I expect the HD brake controller is the same.
Here's a a link to a comprehensive technical evaluation done by one of our HDRAMS members. Original link to HDRAMS thread is in there as well.
There is a ton of information in that post
Next time I try towing I’m going to try some of the other settings (heavy electric etc ) to see if there is a difference or if there is some kind of short causing the issue
Does anyone know if ram has a fix for this, I just purchased a 2022 last week and the trailer brakes drop off at 15mph truck has 800 miles so far
My factory trailer brake controller stops working when my speed drops to 15 mph and below.
Actually, the ITBM starts reducing the braking signal to the trailer when travel speeds fall below 30 MPH. I first noticed this on my 2015 and RAM introduced a software update in November of 2015 for the ABS and trailer brake module which altered the braking behavior but still pulled back braking as travel speed fell below 30 MPH.
Just about every RAM forum has a discussion like this for each MY since this issue first appeared with the 2015 ITBM.
If anyone is interested in actually watching what the ITBM outputs, get one of these devices and watch (in amazement) the braking signals.
Has anyone had this problem solved yet? My 2020 1500 has been doing this since I got it and I’m getting sick of having to deal with it.
Never figured it out for mine. Dealer was useless and I just learned to drive around it.. sucked, but I lived with it.
There are only two ways to resolve this: a software update from the factory or adding an after-market controller like a Prodigy. The latter is what I did with my 2015 until RAM came out with an update. It was very difficult to get someone at RAM to listen to the problem with the ITBM. After enough complaints to the NTSB, RAM updated the software. Why they continue to do this is beyond me, and the only explanation I have is the folks who designed the trailer brake controller never towed a trailer with brakes.
