No Driver Side speakers working??
Repsol69
Ok, it seems like my driver side speakers have stopped working..I've tried everything from disconnecting the battery to checking the wires under the seat nothing works... even the nav voice is very low...???? Whats next??? Truck is a 2019 with 54,000 miles
Could be blown speakers… it’s not uncommon…
Is your phone and/or cable connected when this happens?
ok, Dealer said the ANC module is blown on the left side...i replaced it and it i still have no speakers on the drivers side...
I have a similar issue. My driver’s side door and dash speaker will work on occasion (getting more and more rare that they do work). Mine is a 2019 that JUST crossed the 36k mark. I know the speaker isn’t blown because it sounds fine when it does work. This happens no matter the source (phone, radio, Sirius, etc).
Because of this, nav thru CarPlay will not work at all, meaning I pretty much have to keep my eyes OFF the road to figure out where I’m going. I bought this truck CPO not even 3 months ago (free Sirius is still active).
Because I drive a lot for work, I’ve already eliminated the CPO warranty, so it looks like I’m pretty much screwed unless anyone has any ideas.
Usually it seems to work after I do a soft reset, but only for one good drive before it’s out again for longer than it worked. And yes I’ve used the balance fade screen to test and when I move the indicator toward the front drivers side I just get no sound at all no matter the volume.
Did you ever find a fix for this. I'm having the same issue.
2019 Ram 1500 - same issue. Driver side speaker is out. A radio guy said it could be the full stereo needing replacement - Dodge quoted me "at least a grand." So, I'm just turning it up...
The key here is figuring out whether it is the head unit, the ANC, or the speakers. Unlikely to be the speakers if it is both door & dash that are out.
An ANC Bypass would help with testing - hook it up and test for audio with some other speakers (house bookshelf speakers, whatever) - if this works it's your ANC. If there's no joy then it is your head unit.
All of this assumes a Base 6, not Alpine system. Testing the Alpine system would be a little different since the ANC is signal processor and amplifier both, making it a more likely culprit.
