2019 laramie stock 20s/ off road tire size?
DK04
I’m looking to do a 2 inch rough country leveling kit on a 19 laramie. Also I plan to put nitto terra grappler g2 on the stock 20 inch wheel. Does anyone have any pictures of aftermarket tires on the stock 20s? I was told 295/60r20. What size do you recommend without rubbing?
Most common that I have seen guys running are 285/65r20 and 295/60r20. I plan on leveling my 19 Laramie as well and putting on 295/60r20. Gives it a good look in the wheel well without having to worry about being "too tight". I would also love to see some pictures with a 295/60r20 from a side angle point of view to get a real depiction of what it looks like.
I agree. I don’t want anything too aggressive looking. I want a clean look. I might even go with a 295/55r20. Does anyone have any pictures?
Did you get the tires? If so, were there any issues with fitment?
I went with the Readylift leveling kit with 285/65/20 BFG KO2s. Very happy with the new setup!View attachment 9945
Dont see too many 6.4 beds around. I pull a travel trailer and when I do, I need the bed space for support equipment. Looks very nice!
Readylift front spaces leveling. KO2 35x12.5x20 on stock Laramie wheels.
Personally I love the way it looks.
6 foot bed unite!!
I will post a picture of mine when I get a chance
^^^. I can’t see why not as going from passenger tires to load range E is quite a weight difference. I went taller then stock but with LT tires and definitely saw a decline. Nothing that I would write home about,but carrying that extra weight will do that to yaaa. :)
Any rubbing or trimming with that set up?
Installed the Rough Country 2' Leveling Kit added Nitto Ridge Grapplers 295/60R20 to the Laramie stock 20" wheels... Absolutely no rubbing at all.
20314
