Active grill shutters question.
Synergy26
I have a 2020 ram 1500 ecodiesel. I was playing around with alfaobd and notice that the active grill shutters (AGS) is turned off even though my vehicle has them. So my question is should this be turned on or is it turned on somewhere else? I'm not sure I should turn it on and possibly cause an issue. Anyone familiar with this? TIA
It looks like it’s turned on in the pic? You can tell if they are working by looking at them when you start the truck. They will cycle. Also, if they are stuck closed you will more than likely overheat
I turned it on but then back off, it was off to begin with. I had to choose one or the other initially to figure out where it was. I wasn't sure if since the ecodiesel had two active grill shutters of it is called somthing else or turned on somewhere else in alfaobd
oh ok. sry not familiar with ecodiesels or alfa. Maybe someone else can help.
