Wheel and tire Combo
Golfzilla184
So after months of anguish doing research and endless calculations i think i settled on my wheels and tires (see below). They are 20x10 -12, from everything i can tell using these wheels i can get tires that are 305/55/R20 without rubbing or trimming. Is anyone else here running this tires size with the readylift 2" level with UCAs? I would really appreciate everyone's input and help before i spend 3k lol
Thanks in advance to all for your help
Yep. That's my set up. No rubbing.
The amount of poke depends on whether you have factory flares or not. It’s a tiny bit below 1” past flares for the wheel itself, and tires will be more than that. (Which idahoktm will be able to answer for you)
The tread is flush with my flares, but the sidewall pokes out about 1" in the front.
Oh yeah, oops. I always think about the front when answering these and forget about the rear having a narrower track.
I didnt even think of that, No i dont have factory fender flares
thanks, this is def helpful. I should have mentioned that i dont have the factory fender flares. I will poke out a little bit more then.
