dutchman187
- May 10, 2018
Had oil changed today at dealer (20% left on monitor). Very nice lady helped me but as I was about to drive away she gave some interesting (and I think flawed) information.
-She said the oil monitor is straight time based and we cannot rely on it at all
The manual says:
Oil Life Reset Your vehicle is equipped with an engine oil change indicator system. The “Oil Change Required” message will display in the instrument cluster display for five seconds after a single chime has sounded, to indicate the next scheduled oil change interval. The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate, dependent upon your personal driving style.
-She said if I do not change the oil every 5K miles, it will void my warranty. Btw, she said she used to work in the warranty department of a different dealer.
I told her I thought the owners manual said to follow the interval indicator, or no more than 10K miles, or 12 months, whichever happens first. She said the manual also says OR whatever your dealer recommends for service and that their Mopar reps tell them 5K miles, so that trumps those other numbers.
The manual says:
Engine Oil — Gas Engine Change Engine Oil The oil change indicator system will remind you that it is time to take your vehicle in for scheduled maintenance. Refer to the “Maintenance Plan” for further information. NOTE: Under no circumstances should oil change intervals exceed 10,000 miles (16,000 km), twelve months or 350 hours of engine run time, whichever comes first. The 350 hours of engine run or idle time is generally only a concern for fleet customers.
And also: "At Every Oil Change Interval As Indicated By Oil Change Indicator System"
And also:
SCHEDULED SERVICING Your vehicle is equipped with an automatic oil change indicator system. The oil change indicator system will remind you that it is time to take your vehicle in for scheduled maintenance. Based on engine operation conditions, the oil change indicator message will illuminate. This means that service is required for your vehicle. Operating conditions such as frequent short-trips, trailer tow, and extremely hot or cold ambient temperatures will influence when the “Oil Change Required” message is displayed. Severe Operating Conditions can cause the change oil message to illuminate as early as 3,500 miles (5,600 km) since last reset. Have your vehicle serviced as soon as possible, within the next 500 miles (805 km). Your authorized dealer will reset the oil change indicator message after completing the scheduled oil change. If a scheduled oil change is performed by someone other than your authorized dealer, the message can be reset by referring to the steps described under “Instrument Cluster Display” in “Getting To Know Your Instrument Panel”. NOTE: Under no circumstances should oil change intervals exceed 10,000 miles (16,000 km), twelve months or 350 hours of engine run time, whichever comes first. The 350 hours of engine run or idle time is generally only a concern for fleet customers.
When I mentioned the manual information and info I've gleaned off the board the last 4 years, she said "if you want to take a chance on your warranty it is your truck." I said I feel like the goal posts keep moving if the manual says one thing and each dealer can make their own rules. She said she wished it was like a Starbucks where it is the same everywhere, but it isn't.
BS. That is exactly the point of the owner's manual, to make it uniform. These people **** me off and knowing they are the ones reviewing warranty claims in the future make me mad in advance.
I will likely find a different dealer, even though I'm sure I'll encounter bad service advisors everywhere.
The manual says:
The manual says:
And also:
