Auto Emergency Braking Error.
jirving
Bought a new Bighorn Night Edition last week and intermittently get the "AEB Unavailable- Service Required". Would love to just disable the entire feature, but even when it's off the error message occurs. Called service and they said they've "never seen this before". Find that hard to believe.
I had that issue, they had to replace the module behind the rearview mirror. Part # 68475159-AE
I had that once. I forgot to kick the step back up underneath and I was parked at the curb. I just pulled away. So I didn't back up to get the alarm that sensed something in the path, I got that message instead. There was lots of angry language until I got home and saw the step was still down. It cured itself as soon as the step got put back out of sight.
Just got this warning myself along with Auto high beam being unavailable. Middle of the day, cruising at 65mph down the interstate. 800 miles on the truck. Came on for maybe 10 seconds and then went back to normal.
Maybe you hit a bug and it tripped up the system, and it corrected after the guts finally flew off.
That tells me you don’t want to deal with that service department. There’s way too many possibilities to narrow down the cause while sitting behind a keyboard, but a good place to start is by checking the historical codes in the BCM.
My '22 just started this when first moving I'll even get the headlifghts flashing a few times till it stops. It will do it occasionally after while just driving. I'll check BCM history in the morning any other insight would be a help
Bringing back an old thread. Anyone know if there’s a flash update or something else that addresses the "AEB Unavailable- Service Required" error message? Happens intermittently. Have a service appointment but I’m sure they’re just going to tell me the usual could not duplicate.
My 23' Laramie does this randomly once in a while. If I have the Adaptive cruise engaged it will let off the throttle, maybe give a quick brake tap, then resume normal function. One section of road on my commute runs along high tension wires for about half a mile, then the wires cross over the road diagonally. Every time I drive under the wires the AEB message comes on, Adaptive cruise will disengage if I'm using it, brake tap, and an "Adaptive Cruise unavailable, wipe front sensor" message with a nifty little animation of a Ram truck driving across the cluster. When this happens, it lasts for about 30 seconds before going back to normal.
Awesome thing is, this condition is easily repeatable & this section of road is within a half mile of my local CDJR dealer. I'm at 21,000mi. now, and will be out of bumper to bumper in the next 4-5months. This is on my nitpicking list of warranty complains to take care of before it expires, along with the non-canceling left turn signal, inop gauges on the trailer towing page in UC5, & a few more...
My 25 Ram started doing this with about 100 miles on the truck. 🥺
This thread makes it seem like a fluke. Other threads make it seem like a faulty sensor up in the mirror?
Mine's been coming coming on intermittently as well since about 900 miles and today the AEB, Traction control, 4WD unavailable, service required, and CEL came on. AEB just started to work a week ago and now hopefully I have a code so I can get it resolved
Hi, my 2025 Tungsten is doing this from the very first day I bought it and then it developed an engine issue. Took it back to the dealer and they ended up replacing the engine. Pick it up yesterday, everything was good until I made some changes in Uconnect to get everything back to my original settings, then BAM!! the AEB warning came back on, lights on the dash and the mirrors are on. I only have 551 miles on this very expensive (very nice) truck. Then found this - https://static.nhtsa.gov/odi/tsbs/2025/MC-11019446-0001.pdf. Apparently, you cannot make more than 4 changes to the settings on every start up cycle. Now this is something that some very intelligent coder somewhere in an obscure development center came up with. Or perhaps this is what happens when you use AI to write code in mass production, regardless, this is something that should be addressed rather quickly. Hope this helps out someone else out there. Like the truck, just annoyed at getting something brand new and spend more time driving it to the dealer than enjoying it on the road. Cheers!!!
My 2025 Limited Night Edition started showing Auto Emergency Braking (AEB) Unavailable - Service Required. It came in middle of a drive till I reached home. Next day when I started my RAM 1500, No Error! Yesterday it came back again and now it wont reset. Did you resolve your Tungsten AEB warning issue? If yes, what they did?
Hi, no resolution as of yet, this seems to come up every so many start up cycles or when there are any updates being pushed over the air. Right now, I am just reporting it to the dealer and will wait until the firmware update is available, hopefully Q4 this year as the bulleting states.
