ANC location stock 6 speaker system
Distruck
I am ordering up parts to install an amp and sub on my 22 Ram crew cab with 6 speaker 8.4 Uconnect 5. I am reading about the ANC bypass but there is no module under the seat. Is there perhaps another location?
Do you have a Hemi? I believe only the hemi has an ANC.
I don’t have a Hemi. And I believe that you are correct because I read that somewhere after I posted the question. So I am going to assume that there isn’t one. Thanks!
What engine do you have?
No ANC system. So you can't use the by-pass harness to tap out and in for amps or dsp. Which is very unfortunate. There is a harness that Ts behind the headunit. People with alpine units use it. I haven't been able to verify yet if the 22 head unit harness is the same as 19-21.
