deeve
I had read in some of the dozens of reviews of Ram trucks that ones equipped with a locking rear axle also acted as a limited slip when not locked. I dug around some and found one video or forum post that discussed that, but cannot find it now. Anyway, I thought I would test that our when my BH BC showed up with the locking rear axle. Having owned Wranglers with both anti slip and locking the concept of this was intriguing as it would be a cake and eat it too situation.
Fast forward to today when I found myself on a dirt road. With traction control off and in 2wd while flooring it I was able to get two distinct rear tire acceleration marks. I tried it a bunch of times with the same result each time. Each time there was not even without a hint of a emulated electronic limited slip function like Wranglers have using the ABS system. I forget the name of what Jeep calls that and I don't know if our Rams have it. Kinda assume we do as part of the traction control system. I looked particularly close for that as I think you cannot truly deactivate traction control. In my experience with the electronic limited slip there would be shading from side to side as the abs system modulated power. I did not see that.
I am no axle expert by any means, but take a look at the photos and let me know what you think. The road surface was a bit damp and had loose gravel on the shoulder and packed in the middle. I conducted the "test" with one wheel in the looser gravel and one on the packed as well as both on the packed. You can see the gravel is darker but that is because of the surface. Closer toward the middle of the road things were equal. Toward the end the right tire was marking more, but at that point I was in second gear and moving at a pretty good speed. Limited slip would act like that too, if I recall. This test is not as good as on ice or snow, but I think something more than an open differential is going on.
