2inch lift Ram Rebel non air ride.
LilChico
Toronto, Canada
Looking at getting the Mopar Fox 2inch kit from my dealer. First question, is this a good kit and is it safe for the truck? Second question, knowing the Rebel has a 1inch lift over other rams. Will this kit give me a true 2inch lift? Thirdly, will I be able to get 35/12.5/18
on with out having to make any cuts? I would appreciate any help or recommendations!
H2OMAN
The O.C.
It is one of the best kits there is. Yes it is fine for your truck. Yes you will get 2" of lift. Yes you can fit 35's.
LilChico
Toronto, Canada
So will it be 2inch in total or 3 cause of the 1 inch lift from factory? What I’m trying to make sense of is by changing to the fox kit does that get rid of the factory 1 inch lift. So technically is it only adding 1 inch to stock lift?
H2OMAN
The O.C.
Yes it does get rid of the factory 1 inch lift. The Bilstien and the Falcon lifts use the factory coil so you could get 3 inches. Not the Fox.
H2OMAN
The O.C.
I don't really have a horse in the race. It's all dependant on what you want and your budget. All three are very fine kits.
Dan Houle
Lake Alfred Florida
Got a 2" Ready Lift level kit. Put BFG 35"/12.5 KO2's on my stock 18" rims, zero issues. Drives great, zero rubbing, not even close. I did get my speedometer calibrated too.
LilChico
Toronto, Canada
Which ready lift kit is it?Do you see a noticeable difference in height with that kit? I’m maybe thinking of going with the 3.5 in lift. So I can actually get 2 inch lift.
Dan Houle
Lake Alfred Florida
All I know is it's the RL 2" kit with the UCA, not sure how to tell the difference between them besides the height. It definitely leveled it.
70runner
SOCAL
The Bilstein's leveled my Rebel, within 1/4". On the 5th slot, they added about 1.8" over factory. Added the Mopar UCAs for expanded BJ travel, maintain factory appearance.
