2020 Ram 1500 3.5 inch Readylift with 295/55/22's, I need to remove mud flaps
jakeintexas
Hello,
I recently installed the 3.5 inch Readylift kit for my 2020 Ram 1500 Laramie Night Edition. I then installed 295/55/22's. I have some rubbing when at full turn and I'm thinking about removing the front small mud-flaps that came stock with my truck. I also saw another video of someone removing the air-dam which I'm thinking about doing. Thoughts on removing the air dam? I can't tell if it's the mudflats or the plastic fender lining I just need to pull back that hangs down a bit.
I believe the rubbing is coming from the plastic fender lining, any tips for keeping pushed back?
Hello,
I took of the air dam a long time ago, makes the truck look great!
Be sure to heat them up and place something against them until they cool. For some reason, they want to return to their original shape, but a 2x4 to apply pressure until cool will make them reshape, and stay put.
