cervelo15
Let me start by saying in my confusion about which is the best tire pressure to run, I have this forum to thank for clueing me into the chalk test. I branched out and did some research, watched some YouTube videos and it seemed like the simplest test with such a big impact.
So I wanted to share my experience with doing the test this past weekend. I did this after warming the tires up after driving for a bit. Our house is on a hill and a curvy road to get out, so doing it right out side my front door wasn’t a great test because i couldn’t drive in a level, straight line. Colored each of the tires with chalk on a 6” cross section. Drove 100’ forward, then backed up on the same line making sure not to turn the wheel.
Front tires measured 40.6psi cold, went to 43 after driving
Rear tires measured 39.5psi cold, went to 42 after driving
Heres the results:
Front Tire - notice, the chalk was all worn away evenly; the red lines outline where the chalk was on the cross section
Rear tire - there was some chalk still left on the outside edge, but not much, I may still reduce the pressure even more in the rear. But overall, not bad.
But I’m gonna say, this was nowhere near the 36 psi that it called for on the door jamb sticker. When I had my previous Laramie, I ran 40 psi all around without any issues and the tires wore perfect.
Im hoping this helps someone out who’s looking for the right air pressure.
Heres the results:
