Not trying to pick on you, but how’s the inflation on your tires (bulge at bottom of your pic makes them look underinflated) and is your alignment ok?Have Toyo AT3 305/45/22 on stock rims, after 13K miles in the North East they have performed very well on dry, wet, snow covered pavement, dirt roads, grass fields and ice storms. I run them at 40 PSI and have zero road noise. only complaint is they seem to wear fast and I will be surprised if I get to 40K before having to replace.
		 . I could not be happier with them. Look amazing, ride better than stock, and noise is so negligible you have to be going 40+ with the windows down and radio off to even convince yourself they might be louder. Not even close to rubbing in Aero as best I can tell. Didn’t check entry/exit but didn’t care so much about that.
		 ) every day since I picked her up early last week so she’s dirty but I did put 305/45 22 Toyo OC A/T III’s on it this morning.
