Lowering a “north edition”?
J-barcarp
54 year old teenager
Just North of Detroit
I have read conflicting info on what the suspension on my truck is.
i dont have another normal big horn or org big horn to compare to.
i reached out to maxtrack and their answer was ” we dont know”
do i need anything other than the maxtrack springs in the rear?
do i need anything other than the maxtrack kit in the front?
i am afraid i might need the hardpan bar and end links for the rear
and new oem length springs up front.
edit to add.. i know nothing about suspension.
No, but the maxtrac front shocks can be used to lower the truck 3in. So if the north edition has ORP springs, all he has to do is set the clip at the 3in drop instead of the 2in drop.
adjustable Panhard bar is a choice but not required. And the maxtrac kit comes with end links
OK thanks. The situation and why I’m even posting without giving an answer is because I just sold him a set of 2 inch rear Maxtrac lowering springs but didn’t know that he was trying to achieve a reverse level on a north edition truck. So my springs will put him down 3 inches lower in the rear, and he only needs to go 1 inch down in the front. I am thinking that his north edition springs would be fine, but I have non ORG springs available if he finds the spring rate of the north edition too rough with the maxtrac shock valving. Do you feel that your front end feels too soft or is it already firm?
Ahhh gotcha I see what he is doing now.
And my front feels the about the same as stock
Sorry ive been offline all day.
You guys are awesome
I only understand half of what you say but you are awesome.
Let me digest this and look under my truck sat and i will update then.
Ok going out to look under truck
Now…..
My
Sticker says bighorn/lonestar
23z package and
“North edition”
And my build sheet lists
Package t2z and 23z
It also says front and rear extra hd shock absorbers
And
“springs” on all four corners.
Install complete. Drove for a couple weeks and seems to jump sideways a little when i hit bumps. Also tires screech a little during slow corners.
Any suggestions?
