VLED 1800LM BACK UP LIGHT INSTALLATION
CMil527
Old Bridge, NJ
WHICH WIRES ARE YOU GUYS TAPPING? I FOUND A POST ABOUT WHITE WITH PURPLE BUT THERE IS A SPOT FOR 2 WIRES IN THE TAP DO U EED A GROUND?? ANY INPUT WOULD BE APPRECIATED!! THANKS IN ADVANCE!
Anyone?? a simple wire to tap without buying curt connectors yada yada???
Hey! So I am wiring my reverse lights here soon. Tapping into the trailer plug from behind. Pulled off the gray cover and I believe the middle black wire is going to be the reverse light signal.
thank you sir... lmk for sure if that's the one!!
