HELP, code C2212, U05BF and C10D0 can't clear with AlfaOBD
damonb
I tried changing tire sizes in AlfaOBD on my 2021 Ram and even after doing the ABS initialization, I cannot get these codes to go away. Cruise and FCW are not working and have trouble lights on the dash, everything else is fine. I did set tires size back to what I recorded as original circumference.
Ever get this figured out? I'm having the same problem. I threw a bunch of lights and codes in the process. I've got most of it cleared up, by my parking brake warning light is on and code C10D0 won't clear.
Did you save your default settings before you made any changes? If so, try to restore.
He did say "I did set tires size back to what I recorded as original circumference." and still can't clear the errors.
That doesn’t mean he didn’t inadvertantly change another setting though as several members have done and ended up in the same type of situation.
Check the bottom for how I resolved it.
Hey thank you! I’ll give it a try tomorrow and let you know how it goes
Worked like a charm. Glad to have the code gone. Thank you
