Amp for EVERYTHING?
ryanc721
I just replaced all 6 speakers in my 22 BIgHorn. Im trying to power them and then add subwoofers. What's the easiest way to do this? 5 Channel amp? two separates? Go from behind the dash or from under the driver seat? I need suggestions from anyone who has done this. thanks!
Multiple amps are always better, installation is a bit more complex but you get better results i suggest a 4 channel for the dash and front doors, (leave the rears alone, after all you seat up front) and a single channel for the subwoofers, behind the rear seat there's plenty of room to install multiple amplifiers, just have to make a mounting panel.
so I can run one of these and then line out it to a mono amp for the sub? or do I need a converter after the line out?
Op- there’s one of those Ap-41’s for sale in the For Sale section right now
The CH41 isn't plug n play on the 22s due to UConnect 5. You can use it but need to hardwire it in.
