Auxbeam 8 gang switch panel installed
Snow White
Valencia, CA
I'm installing mine now so I can get ahead of everything that I'm adding to my build.
I like the On-Off-On Toggle you ran. What pin position did you use in the fuse box for the ACC Fuse Line
Bigty
Someone asked about my switch panel so I thought I'd share in case anyone is looking to do the same.
Nice, i'm going to do the exact same thing. As the other fella asked, where did you pull the power from for the on / off / on switch?
