Reverse Lights For 4th and 5th Gen Ram 1500 as well as TRX with Rear TRX Tow Hook Brackets
Gilbert Arizona
Our reverse light brackets are up for preorder at a discount. These work with any truck that has a rear TRX Tow Hook. The brackets mount to the rear two bolts of the TRX Tow Hook. The light is a Diode Dynamics SSC1 pod light with a red back light and white main light. for best results wire the main light to your reverse light circuit and the switch included in the wiring harness. Wire the red backlight to the tail lights or brake lights to add extra red light to the rear when needed/wanted. The white light provides plenty of extra visibility while backing.
I'm looking forward to it!
Is this the harness that will be included with the kits:
Yes it is.
