Can you drop in a lithium battery?
Jonz
So I'm looking for ways to lighten my truck for gvwr while towing. I've come up with a few ideas but one I can't seems to get a definante answer is if i can remove my heavy agm battery and replace it with a lithium/lifepo4 battery without changing the charger? I know its kinda costly but the weight savings and chances are ill never need a new battery again makes it worth it in my opinion.
Someone who has done it successfully has posted on page 2.
I've done it. It works great,
18.5lbs VS 53lbs stock AGM.
Stock 53lbs.
battery-jpg.53494
Wow! That is steep for 45 pounds. I guess a good start would be a stripped bare Tradesman.
Ye3s you can, you can even add one to the factory one, I installed mine behind the back seat what the factory subwoofer location, of course mine is custom made to fit but it's pretty easy, i can delete the front battery now if i want to.
