DRL - Issues/Questions - Need Help
BMRAMAU
Hi,
I have 2021 1500 Limited with daytime running lights. When the headlights are turned off they are fine and operate as per normal. However, as soon as the headlights are turned on the driver's side DRL stays on and the passenger side DRL's turn off. Does anyone have any experience with this and know where to look? I don't know why the two headlights operate differently.
Thank you in advance.
do the headlights work correctly if the switch is set to have the lights on? I assume your issue is with the headlight switch in the auto position.
Take it to the dealer. I'm assuming your 2021 is still under warranty.
Its disabled in Australia so the dealership isn't helpful trying to work around here.
It seems I have constant power to pin 13 on headlight plug but don’t know why?
It should switch in and off with lights.
