Help! Maxtrac springs and airlift 1000
Gitchapull
I have the maxtrac 272720 2” rear springs and the airlift 1000 pn# 60818 as advised by accessory partners.
The issue I’m having is the top plate or spacer, that comes with airlift is slightly too small for the coil bucket on my 22 Laramie. They are just small enough where the they start to angle and one end starts to come through the top of the bucket.
Has anyone else had this issue? Does airlift make a larger diameter spacer ?
This is gonna be a dumb question, but did you put the rubber spring isolator back on top of the new springs?
Edit: just saw it's there. Nvm
I had a local mechanic put them in. He Actually ended up using the top plate of the first set of airlift bags I ordered but never installed which are part number 60824. They were larger than the plates that came with the 60818’s. I ordered those before consulting accessory partners.
I did the same thing with buying 60824 first, but the top plates for the 60818s fit with my stuff.
No one else with this issue? How are the holes at the top of the coil bucket larger than anyone else’s?
