Iphone 13 case compatible with wireless charger
HeloWrench72
Looking at getting a new iPhone case/cover for pro max 13 that is compatible with the built in wireless charger. Any suggestions? If this has been posted, I apologize. I didn't see it when I used the search feature.
I don't think the case has anything to do with it, that phone should charge through the case you put on it.
It does matter, depending on the case you get it won't fit on my 21 Limited.
I use the standard case from apple and it works good. My Speck case wouldn't fit, it made the phone too tall.
Tom
I use a spigen ultra hybrid. It’s low profile and works well. I’ve been using these since my iPhone6, and love them.
I use the Spigen Liquid Crystal cases. They look exactly like the case you have. Minimalistic, tough enough to survive drops, and they work well with wireless charging. Hard to believe you can get them for $12. 👍🏻
Tom
my bad...wasn't thinking about the size of the case, was thinking of the signal passing thru the case. You're right, the slot they give you to slide the phone in is pretty tight!
For the iPhone 13 Pro Max, you'll want to look for cases that specifically mention compatibility with MagSafe or wireless charging.
I recently found this awesome site that has a wide range of cases for all kinds of phones, including the iPhone 13 Pro Max. They have filters to help you find cases that are compatible with wireless charging, so you can easily narrow down your options. This might make your search a lot simpler and ensure you find a case that not only protects your phone but also works seamlessly with your charger. You can check it out here.
