When it says 6-8" lift, does the 2 inch difference occur by adjusting the front coil springs or is there some other reason?Belltech.
Depends on the kit. One kit has adjustable struts, and the other had adjustable coilovers.When it says 6-8" lift, does the 2 inch difference occur by adjusting the front coil springs or is there some other reason?
Which one do you think would provide a more stable/better ride?Depends on the kit. One kit has adjustable struts, and the other had adjustable coilovers.
Do you plan on doing a good amount of off-roading? That would be the only reason to pay extra for the coilovers. On road there shouldn't be much of a difference. The Belltech kits haven't been out long, so you probably won't find any reviews here as of yet.Which one do you think would provide a more stable/better ride?
We probably spend 30% of our time off roading in Texas. Sounds like the coilovers would be a better buy. Is this what you have on your truck?Do you plan on doing a good amount of off-roading? That would be the only reason to pay extra for the coilovers. On road there shouldn't be much of a difference. The Belltech kits haven't been out long, so you probably won't find any reviews here as of yet.
Yes, coilovers would be the better option. I'm currently running extended length Fox racing coilovers. Set at 3" lift.We probably spend 30% of our time off roading in Texas. Sounds like the coilovers would be a better buy. Is this what you have on your truck?
That’s not the way engineering is usually done, especially with something that could cause a catastrophic failure and kill people. The engineering will be for the worst possible conditions, or in this case, the tallest lift. Talking with BDS would confirm that.Almost 100% of the time if it’s a kit that’s “adjustable” from say 6”-8” it’s actually a 6” kit but the struts/coilovers/spacers are giving it another 2” and almost acting like a leveling kit on top of a 6” kit, which is why they usually strongly recommend UCAs if you “adjust” them to the upper setting. The scary thing is, BDS for example uses the exact same kit for the 4” and 6” lift, the only difference is spacer size/coilover length, so let’s say you want to make a BDS 6” kit into an 8” kit by adding a spacer on top, you’re basically stretching a 4” kit all the way up to 8”! Because of this, I think your best bet may be to do a 6” lift and then add a 2” body lift that way it’s at least not stressing the suspension more! Just my 2 cents
Thanks for the great info. Any idea what the best body lift would be for our trucks then?Almost 100% of the time if it’s a kit that’s “adjustable” from say 6”-8” it’s actually a 6” kit but the struts/coilovers/spacers are giving it another 2” and almost acting like a leveling kit on top of a 6” kit, which is why they usually strongly recommend UCAs if you “adjust” them to the upper setting. The scary thing is, BDS for example uses the exact same kit for the 4” and 6” lift, the only difference is spacer size/coilover length, so let’s say you want to make a BDS 6” kit into an 8” kit by adding a spacer on top, you’re basically stretching a 4” kit all the way up to 8”! Because of this, I think your best bet may be to do a 6” lift and then add a 2” body lift that way it’s at least not stressing the suspension more! Just my 2 cents
Well BDS doesn’t make an 8” lift for our trucks, 6” is the tallest. So making their 6” into an 8” lift is beyond what they engineered it for, so my point is still trueThat’s not the way engineering is usually done, especially with something that could cause a catastrophic failure and kill people. The engineering will be for the worst possible conditions, or in this case, the tallest lift. Talking with BDS would confirm that.
