Automatic self lacing. Key fob is level 1 - wait that was changed to group B. You can't get that option on all models.What options were removed from the boots due to the chip shortage?
Heated soles, backup alertsWhat options were removed from the boots due to the chip shortage?
The bigger question for the air ride soles is how’s the reliability when it’s really cold? Hope I don’t get the COVID model.But does it have air suspension?
Does the price include both boots?
I believe the option they removed the traction control. I could be wrongWhat options were removed from the boots due to the chip shortage?
With 2" spacer and Hellyeah sway bar. They shouldn't rub as long as you have it in 4 wheel low.Can I run a size 14 on a OEM size 11?
FIFYWith 2" spacer and Hellyeah sway bar. They shouldn't rub as long as you have it in 4 heel low.
FIFY
Well not sure about you but i lace to the top then run the laces back around the top of the boot and back out the front with a double knot, to reinforce my ankles.Do you guys like to attach the hellyeah at the first or second eyelet?
You don’t want them…The alignment’s off and they leak.Let me know when ramboxes inserts on the sides come out…so I can put my money in it, instead of my pocket.
2022 Ram 1500 Back Country
2016 Dodge Charger scat pack
2021 Jeep Wrangler Unlimited Sahara (wife)
