Dogpatch
Fuel consumption is directly related to the force provided by the lower right appendage against the throttle pedal. Its downward pressure, thereby causes a diminished distance between the throttle pedal and the floor board, resulting in rapid forward movement. It is further influenced by both the speed and the frequency in which the distance between the two points is narrowed.
Although some monetary deficit will occur, feelings of elation normally overtake any urge to counteract the release of the applied downward force.
You’re welcome!
You’re welcome!
