Anyone Running 295/50R22? Do They Fit 9" Rim?
Saddlerocker
I have been back and forth between 285/55r22 and 295/50r22 for my Laramie Night Edition.
I dont have much rake as it is now, so I am considering adding just the 1/2" Wulf spacers to the front.
I am wondering if the 295/50r22 will fit with just a small level in the front.
llI am mainly interested in a thicker sidewall, so I am not looking at 33x12.5r22 or 305/45r22
Any pictures would be appreciated and any info whether its stock/leveled/ or lifted in any way and any rubbing/trimming.
I dont mind bending a little plastic, but would rather not cut anything out.
Thanks
So now I am confused...
Does a 295 not fit on the 9" wide wheel?
I assumed the range shown on Toyo's site meant 9" was within the range.
It says 8.5-9.5-10.5 with the 9.5 in bold.
Does that mean it only fits a 9.5" wheel? Or is it any size between 8.5-10.5?
Toyo's site states "Bold designates measuring rim width" ? Whatever that means?
I included the 285/55 chart also where 9.0" is in bold obviously meaning its a good fit.
How are people putting 33x12.5 or 305/45 on stock 22's?
They’ll fit on the rim…. They did on mine.
I have a 2 inch level though with zero rubbing.
Thanks.
I ordered them the other day anyhow.
I was just confused on how Toyo was listing it when I posted this.
how about 295/50R22 on stock, air ride limited?
any rubbing?
My 23 Limited had 295/50r22 Nitto RG on it when I picked it up. Obviously wider than stock, but they fit and no evidence of trimming. Actually has the RAM splash guards front and rear. I went to the 285/55r22 to go back to stock width, but this adds 1.3-1.5in OD to the tire.
Yes they fit, look good if you want a wider tire than stock. Basically a metric 33x12.50 tire.
Front and Rear Links? Also, have you noticed any pros or cons to the change(s)? Truck looks real good.
Just front links and I did not go all the way level , so it still has a little rake to it.
Thank you for the compliments.
Pros, the stance and it still works like a truck.
Cons, none yet. Did the same thing to my 2014 Limited. Will do it again.
