apiazza
- Nov 20, 2021
I'm planning out the suspension for my '19 big horn 4x4. I'm likely only going to level the front 2". In my 4th gen I used airlift 1000s to help compensate the sag when loaded or towing. I'm curious if anyone has found stock ride height or 1"ish lift stiffer rear springs that might he worth pairing? Most springs that I've found were 2" lift heavy duty.
If I go helper, any input on jounce bumper supports vs the air lift? I've had good luck with the in coil air bags.
Sent from my SM-G991U using Tapatalk
