Exhaust
PapaT
I would like to replace the muffler ( or exhaust) on my 2019 Limited. I like the throaty sound on the TRX. Is there a way I can get close to that without increasing the cabin exhaust noise/drone?
silverWS6
EPTX
Check out the Modifications/accessories section, look through some threads and maybe you'll find something you like.
I have a Magnaflow muffler on mine, minimal drone. I can't remember the dimensions on it but I like the way it sounds.
RamLink83
AWE 0Fg will get you a good throaty sound, however you will have cab noise. It's not excessive, but you can definitely tell you have an exhaust, especially when you floor it.
SD Rebel
San Diego, CA
This is a difficult question, since everyone has a different idea to what is drone and what is loud. I personally would look at the 3 cat-back systems offered by Borla for the DT RAM. They go progressively louder, but even the loudest one (Borla ATAK) is designed to not drone on the highway, even when MDS is operating.
bpwj76
LA
I also have a Magnaflow muffler. There is alomst no drone when cruising. Here's a cold-start for reference for the OP.
Cajun_
Louisiana
Active Noise Cancellation helps and seems to block out the awe when cruising.
