other than a good weight distribution hitch will I need anything else?
Unfortunately the numbers will tell you that this combo is not possible. As stated earlier toyhauler have much higher tongue weights, Especially if you do not put any toys in the back. You will 100% go over GVWR, my guess is your payload is somewhere in the 1400-1600 range, four adults and a high tongue weight will do that to you.I have a 2020 Ram 1500 CC shortbed sport Laramie 4x4 3:21... want to tow a toy hauler 28' and 7000 lb loaded...other than a good weight distribution hitch will I need anything else?
You’re still over with these numbersHere are some more accurate details.... the trailer is 25' minus tongue (28.5' total) 5000 lbs dry, hitch weight of 850. I will use a blue ox 1000 pro WDH. As far as weight in the truck goes 330 to 700 lbs of occupants, 50 lb tonneau and maybe 100lbs misc. cargo. Trailer load will vary but I'd tow with mostly empty tanks and 1000 lbs of cycles max. other cargo in trailer could add up to a max of 500lbs total. My max payload is 1575, Base is 5525 , Max tow is 8200, GCWR is 13900. I think with these new numbers Im around the maximum but not over and within the legal limit?
If I drop the occupants to myself and the wife its only 320 lbs and when the toy hauler get a load wont some of the tongue weight shift rearward as well as the hitch taking some away?850 hitch dry will be 1,000 wet (batteries, propane, contents get added). With the occupant load and the extras you’re over, wouldn’t risk this one. If we were talking non-toy-hauler travel trailer the tongue weight would start 200lbs lighter and be 850 loaded, with much less cargo capacity and chance to overload the truck.
so if I reduce the occupant weight to 320, hitch is really 80#, one battery and one propane tank on trailer and bump up to a 12000# hitch the numbers should work.....I have the helwig sway bar already and need new rubber so I can go with e-rated tires.You’re still over with these numbers
1,575 lbs payload
- 1,000 lbs TW
- 700 lbs passengers
- 100 lbs WDH
- 50 lbs bed cover
- 100 lbs misc
= -375 lbs
I guess I better start looking at 2500's.etrailer lists it at 95 lbs, but now you’re splitting hairs trying to stay under
Toy haulers are tough on a 1/2 ton
I agree that while it can be done , I would be limiting what and who I take with me. I looked today at a 2500 and it have over 3000# payload....almost double my 1500.So. You changed a bunch of numbers already.
Lets look at what does not change first.
GVWR is 7100
Front Axle GVWR is 3900
Rear Axle GVWR is 4100
GCWR is 13900
These numbers do not change. They are capacities set by manufacture.
Payload is 1575
Base weight is 5525.
These are the truck numbers. They are going to change as you add/remove things.
The farce of max towing.
13900 minus 5525 is 8375...note: at this point you have no driver or hitch.
So, 8375 lbs. That is what you can work with.
And this is were your numbers start to change.
So now the camper is 5000lbs dry with hitch weight of 850lb. The hitch weighs 95lbs.
So starting at 945lbs. So with the empty trailer hitched to you truck you got 945 lbs gone. Best case scenario...it is about to go up as you add batteries and propane and supplies.
Best case you have 640lbs left for people and stuff.
You would be surprised what you already have in your truck that is eating into that 640lbs.
Good luck. It can probably be done. Do you have experience towing? How is the terrain? Steep hills, lots of turns? Flat, relatively straight?
My camper weighs about 6300lbs~
When headed camping my truck has 2400lbs of payload. This is family of 4 our stuff, some wood and bikes. My toolbox and stuff under the rear seat. My camper could easily be towed by a 1500...if we took nothing else, to include the family...now we got to take 2 vehicles.
I still got capacity. But a 1500...i would be grossly overloaded.
